na522/3 boards
Posted by: ndx202- on 15 June 2017
Just put the above boards in my 82 replacing the line boards ..Sound is muddy ' shut in and quiet
Can any one advise thanks
Posted on: 15 June 2017 by ianrobertm
Quote - 'Just put the boards into the amp and hooked it up to a k9 on a AR TURNTABLE . It sound nice but volume has to be at 10 past to listen at a reasonable volume.. Am I better off putting the line boards back in and getting a decent phono stage.. Sounds great but just quiet..'
Same....?  Suggest if so, you stay on your original thread.
Posted on: 15 June 2017 by Richard Dane
NDX202, I assume this is the same or similar query to your other current thread.   I'm going to close this thread so you can stick with your original one.
p.s. Worth bearing mind that NA522/3 boards are getting on a bit and not up to NA522/4 standards.
