Help replacement fuse
Posted by: Matthew Johns on 15 June 2017
hi all,
after bit of advice on where to get replacement fuse for naim kit as my xps dr fuse blew earlier this evening which scared the bejeesus out of me
replaced fuse with the spare you get in the carrier but wonder where to get replacement or is it a standard fuse (didn't look like any old bog standard fuse)
advice appreciated as as usual guys
mat
Posted on: 15 June 2017 by Finkfan
Hi Matthew. Your dealer will be able to get you replacement fuses, or google naim replacement fuses and a number of dealers that can help will come up.
Posted on: 15 June 2017 by ChrisSU
You need the exact replacement 'slow blow' fuse. Some XPS's have a reputation for blowing them, so probably best to keep a few spares.
Posted on: 15 June 2017 by Pcd
I had the same problem earlier is year my dealer gave me a couple of spares.
Posted on: 16 June 2017 by Richard Dane
Mat, the fuse must be the exact same make, size and rating.  Anything else will either blow immediately or be unsafe.  Your Naim dealer should be able to supply - get a few just in case.
Posted on: 16 June 2017 by perizoqui
Not sure where you're located, but if in the US, you can get them from Digikey. You want the fuses made by Littelfuse. 5x20 mm in glass. Series 218. I'd provide a link , but it's not allowed. I use them and they work well. My information comes from here:
https://forums.naimaudio.com/topic/equipment-fuses
Best of luck,
---Pedro
Posted on: 17 June 2017 by Matthew Johns
Thanks guys found naim dealer that can supply them via post and the fitting FAQ never considered them being directional buy hey should of known better in our world of audiophile
Posted on: 18 June 2017 by perizoqui
So ac current (what you get from your mains) is bi-directional. If a fuse were directional, it would rectify somehow, and the voltage would build up on one side or the other eventually blowing the fuse. They're not directional, put them in however you like. I mean, it doesn't hurt to put them in right side up, but it doesn't matter if you put them in upside down.
Posted on: 18 June 2017 by Peder
Than we have different experience about this,High Fidelity the biggest Linn-dealer in Sweden ..... always put the fuse in right direction before delivering new equipment.
The differens is not big,but's no problem too hear if you have everything right in your musicsystem.
/Peder
Posted on: 18 June 2017 by Simon-in-Suffolk
Matthew Johns posted:
Indeed Naim have found an optimum direction for their fuses although they admit they don't know why, but they have observed it.
https://forums.naimaudio.com/to...r---which-way-around
