Uniti core backup to a Windows 10 pc
Posted by: Billbee on 16 June 2017
I have configured the share in Windows. But I cannot see the share when  I try a share-scan from uniti core. Can someone please provide the steps required to set this up?
Posted on: 16 June 2017 by David Hendon
You have to tell the Core which shares to scan. It doesn't just scan everything that is shared. You do that through the Naim app, select the Core, then settings, then "Manage Music".
best
Posted on: 16 June 2017 by Billbee
David Hendon posted:
best
Thank you very much for your reply. My broblem is I am not able to see any devices on the network from the uniti core.  I need the steps required to make the Windows 10 PC viewable please?  I can see the core folders from Windows but not the Windows folders from the core.
Posted on: 17 June 2017 by David Hendon
Sorry I don't know the answer to this. It would be worth phoning Naim technical support on Monday. (They don't necessarily pick up everything raised in the forum, so if you don't get an answer  on this thread or the new one you have opened, next step is to call them).
When you solve it though, do please come back and tell us all how you did it.
best
Posted on: 17 June 2017 by robgr
If it's anything like the HDX (which I previously had you may need to ensure that the Workgroup for the device & the kit is the same, e.g. NAIM
robgr posted:
That was with Windows XP (which is what the HDX runs). I don't think this applies in the Windows 10/Linux world.
best
