Uniti Core
Posted by: fotobrooks on 21 June 2017
On my second Core, and it seems to be working as expected. Has anyone come across the front standby light and cd light flashing on and off constantly. Came home from work last night and this is what the Core was doing. Only way to stop it was to turn off and on. Seems to be OK again now. Any suggestions to cause this?
Posted on: 21 June 2017 by French Rooster
fotobrooks posted:
i have it at home and did not really understood why it goes to sleep itself....And to shut it off i had no other solution that putting off the power cord ....perhaps someone on this forum will explain that.
Posted on: 21 June 2017 by Christine
I can explain everything about the Core, but I'd get banned.
Posted on: 21 June 2017 by fotobrooks
Not a fan then!
I'm a fan, but the product is regressive
What product has it regressed from?
Posted on: 21 June 2017 by Pcd
Keler Pierre posted:
fotobrooks posted:
Look up Core on the Naim website it explains what you are asking.
The Unitiserve
fotobrooks posted:
The Unitiserve
Posted on: 22 June 2017 by David Hendon
The front standby light and cd light shouldn't ever be flashing constantly, so it's a sign that it has crashed. Restarting it is the only thing to do. If it happens again then I think it may need to be replaced under warranty again, but you could talk to Naim support first in case they have any ideas.
best
Posted on: 22 June 2017 by fotobrooks
Thanks for this David, will talk to Naim. Bet they'll be delighted if they have to replace another one for me...!
Posted on: 22 June 2017 by Phil Harris
Hi,
By default the Core goes into auto standby (front panel logo turned off) as required by European and US regulations if there is no activity (control from the app) for 20 minutes, however as it is a network product (UPnP server) then for those functions to remain active the unit itself remains active on the network and can be brought out of standby quickly.
There is no physical "on/off" switch on the unit.
Best Regards
Phil Harris
Posted on: 22 June 2017 by French Rooster
my God, damned Unitcorn!  the devil is in the uniti line.
fotobrooks posted:
Hi,
Not something that we've come across before - might seem an odd question but were the power and eject buttons flashing together / in time? Were they flashing alternately? Were they flashing out of sync with each other? If you drop us an email to support@naimaudio.com then we can pick this up with you.
Phil
I know what you mean. Thing is, for me it's a perfect fit, all my CDs ripped and sounding great (all tags and artwork correct). Same with all my downloaded files. Just frustrating if it's now starting to fall over. Perhaps the Phil and the Tech team need a good session on Summer Lightning... believe it's brewed nearby!
The power and eject buttons flashing together. Have just sent an email to support@naimaudio.com
Posted on: 22 June 2017 by Christine
Mine flashes in Morse code which I've decoded as:
          "help me, I need new firmware"
I feel like that most days! Technology... don't you just love it!
Think a long swim, then a cold beer and a strum on the acoustic guitar is called for...
Posted on: 22 June 2017 by ChrisSU
Phil Harris posted:
Hi,
By default the Core goes into auto standby (front panel logo turned off) as required by European and US regulations if there is no activity (control from the app) for 20 minutes....
Presumably this could easily be corrected by a post-Brexit firmware update.
I think Naim are Remainers...
The Firmware is going to remain as it is...
Don't be a spoil sport Christine, a special UK only olive edition would sell like hot cakes.
Christine posted:
i understand your critics and had the same experience...But you said 2 months ago also one thing: the core is a step forward in sound quality vs the serve.   Do you still think this?
Yes, the sound quality is better or at least different vs the Unitiserve.
Although I've not used it since February as it doesn't work properly and I won't rip any new CDs with it as I'm sticking to the far superior Unitiserve.
If it doesn't work properly, why not replace it under warranty?
Christine posted:
Perhaps foterbrook is right, you can replace it buy a new one, the guarantee should work. Maybe a lot of problems in ripping and editing were not only a question of software updates but also the hardware on the first cores was different....?   naim say that the hardware had not changed, but commercially speaking naim audio has no interest to reveal that.....
I'm waiting for my Atom to arrive, I might ask my dealer what he will give me for it.
I can't be bothered trying to explain to Naim why it doesn't work, they'll insist it does blah blah blah
Christine posted:
I'm waiting for my Atom to arrive, I might ask my dealer what he will give me for it otherwise I'll put it on eBay.
I read on this forum that some member had returned their core and received a new one.  Anyway good luck.
