272 connection
Posted by: stuart on 21 June 2017
I have on loan a 272/250dr. Just connected it up but cannot find a connection guide anywhere for these two components - everything but. I have two din to xlr cables in the box one orange Rose  and one green L. I have connected the green L cable to the analogue preamp out of the 272 into the. Xlr input of the 250.
Result only one chanel working. Have I connected it incorrectly or have I been given the left and right din to xlr cables from a 300 possibly (which the 250 was sat next to at the dealers??
Posted on: 21 June 2017 by Richieroo
...hmm think you just need din to xlr sniac stereo - just one lead...... from memory mine was grey. 250dr only takes one xlr. Have you tried the other lead perhaps that is stereo.........
Posted on: 21 June 2017 by hungryhalibut
You have the pair of 300 mono leads.
Posted on: 21 June 2017 by stuart
Thanks Richieroo
I have two black din to xlr. BTW sounds very good with only one channel working
Posted on: 21 June 2017 by Finkfan
Whoops, wrong lead.
Thanks HH I thought that might be the case. Will have to wait until tomorrow for a proper listen.
Posted on: 21 June 2017 by Tallan
Just checked and my 250DR came with a single black cable.  Seems if you have one channel working  maybe try the other cable?  I'm in the US, btw.
Tallan I did think of trying that but don't want to risk causing any damage.
Posted on: 21 June 2017 by james n
You won't cause damage - just the other channel will work instead. As HH says, you have the mono cables from a 300 / 500 instead of the stereo wired 250 cable.
Posted on: 21 June 2017 by Drewy
Yep, exactly the cables I have with my 300. Looks like someone demoed the 272 with a 300 and mixed the cables up.
Posted on: 21 June 2017 by Emre
You got the cables just need the 300 now
Posted on: 21 June 2017 by Huge
The cables come with the power amp not with the 272; someone mixed up the power amp interconnect cables.
So, somewhere, there's also a NAP300 which can only be connected for one channel!
Just out of curiosity I checked my new last week 300DR and both cables are black - again here in the US - and were labelled L & R on the little "source end" wraps Naim uses.  I was hoping for a PowerLine Lite, which I didn't get, so maybe this is older new stock.  FYI.
I thought they had green and red markers on them, but I can't check mine as they're packed away (I made replacements using Mogami W2549).
Emre posted:
Lead me not into temptation!
Huge posted:
The ones I have do have red and green markers on them.
Posted on: 22 June 2017 by Richard Dane
The Stereo DIN-XLR is black and will have a white band.
Posted on: 22 June 2017 by stuart
Thanks all. Got cable sorted today and up and running.
