Help required to optimise my set-up in reconfigured room.
Posted by: Sloop John B on 22 June 2017
I'm lucky enough to have the chance to reconfigure my listening space and now will be able to move my system from between my SL2s. Forgive my rudimentary drawing skills but hopefully for Naim users it's clear enough.
I have to make a decision on where to put the new dedicated plugs. I presume we always need brawn on the right for cable dressing and it's probably best not to have the plugs directly behind the fraim to keep them away from other cables etc. I don't think it's feasible to have the fraim out 1.5m form the wall so although it might not look phenomenal would my red plug be the best place to have the power? I need to power a 300 and 552. I thought I'd put 2 double sockets on the other side of the frame for DAC, turntable and RPi/Roon bridge.
Ideally aesthetically the all the plugs would be better on the left but then power and burndies are running together.
I could always put the 4 Naim pieces on the left fraim but again my perception is that brain left, brawn right leads to better runs of burndies.
Any insights any of you may have would be most welcome.
Thanks.
