4 to 5 pin connector. hicap to preamp input
Posted by: av in bc on 23 June 2017
are there more than one kind of these? namely a snaic and and interconnect?
i just want to replace a non-naim 4 to 5 that is currently tied to a hicap powering a stageline to the input of a supernait with a proper naim one.
my dealer says he has a 4 to 5 but it is a grey interconnect style and not a black snaic.
also i can't find a diagram on the proper installation of a stageline to a hicap, cable direction and especially the correct hicap output to use.
Posted on: 23 June 2017 by Richard Dane
The 4-5 interconnect is not a SNAIC so it will be grey/levender grey in colour.
p.s. There is a very rare 5-4 SNAIC which enables a dual rail power supply like a Hicap to be used on an early single rail pre-amp.
Oh, you can use any of the three DIN4 signal OUTs but best use the one next to the DIN5 to keep signal paths as short as possible.
Posted on: 23 June 2017 by av in bc
thanks, so the grey interconnect IS the one I need to get signal from the hicap to the super.
If it's a genuine Naim 4-5 Interconnect then, yes, it's the one you need.
Posted on: 24 June 2017 by av in bc
ok, thanks. it's ordered and on its way.
