Uniticore, method to delete all music
Posted by: Decnaim on 24 June 2017
Could anyone please outline the methodology for deleting all the music stored on the Uniticore's internal hard drive?
Reason for above, I have encountered difficulties copying music from my UnitiServe to the UnitiCore. Approximately 35% of the music stored
on my UnitiServe has not been copied to the Uniticore. I want to try the copying process again with Uniticore unpopulated  with music,
which will hopefully facilitate the copying of the entire database stored on my 2 TB UnitiServe!
Posted on: 24 June 2017 by Gazza
Just reformat the uniti core hard drive from the manage music menu
Posted on: 24 June 2017 by David Hendon
Gazza beat me to it, but I would give the same advice.
Maje sure that you have the latest firmware and another thing is that if the transfer didn't bring everything over the first time, you can also try importing again. The Core will not copy albums that it has already imported but it should bring any others over. But nevertheless, I would do it again from scratch.
best
Posted on: 24 June 2017 by Decnaim
Many thanks to both Gaza and David for your advice.
Hopefully I will have a more successful transfer this time!
Best Regards
Decnaim
