Garden Planning Software
Posted by: The Strat (Fender) on 25 June 2017
Chaps,
I'm fortunate enough to be able to retire from work Dec this year and have promised Mrs S a re-vamp of the Garden.
Can guys recommend a software planning tool, easy to use and Mac configured.
Lindsay
Posted on: 25 June 2017 by Derek Wright
How much planning do you want it to do?  How big is the garden?
I would have thought that a pencil and paper would do to sketch out the outline, then draw in the type of plants, with a list of the plants you will need.
For different surface textures eg rocks,, pebbles, sand, top soil, membrane jjust measure it up and get at the builders merchants and garden centre.
or
Go to a Landscape Gardening company if you are ready to really spend and want an instant result.
Posted on: 25 June 2017 by The Strat (Fender)
Derek,
its a small garden 50' wide 30' deep so don't really need the professionals!
I've done several paper sketches but would like to see what it might look like on screen.
Lindsay
Just done a Google - have a look at one from Saga there are several listed, I would have a look at the Gardena planner, however there appears to be several.
The secret is to have pinch points so you never see the whole space without walking around the garden.
Thanks Derek.
Posted on: 25 June 2017 by TOBYJUG
Best to get your eye out of the screen and into the green. Put your speakers out in the garden and measure where your garden nodes are. Then plant some nice non reflective lavatera's.
