'No Gap' Playlists on HDX
Posted by: Consciousmess on 27 June 2017
Does the HDX, or for that matter any of the other streaming products have a facility to make a playlist with no gaps between the tracks.
Could there be a firmware to enable this?
Posted on: 28 June 2017 by Klout10
I'm not sure if I understand what you mean, but HDX and other streamers support gapless playback ...
Posted on: 28 June 2017 by hungryhalibut
What he means is can you make a playlist where all the tracks from different albums and singles are effectively joined together, so that 'My Old Man's a Dustman' goes straight into 'Tie a Yellow Ribbon' with no gap. When I did DJing at University parties I used to do it on the two decks, and getting the right transition was quite hard.
I'm afraid that's not possible, it's only possible to play one track after the other with the HDX ...
