Qb
Posted by: JMB on 01 July 2017
I have just become the proud owner of a new Qb. What superb sound quality.
Can any user explain how I can select my preferred iRadio presets. I can see how to delete the factory presets but not how to replace them.
Mike
Posted on: 01 July 2017 by David Hendon
You do it with the Naim app. Basically find them and then favourite each one by tapping the star on the now playing page.
Enjoy!
best
Posted on: 01 July 2017 by JMB
Posted on: 01 July 2017 by hungryhalibut
Make sure you get your favourites as the top five. Then you can select them by pressing radio on the volume knob repeatedly.
Posted on: 02 July 2017 by JMB
HH thanks also. I did actually read the manual but obviously not well enough.
Mike
Posted on: 04 July 2017 by Claus-Thoegersen
Every time you add a new favorite, you are asked if you want to replace one of the 5 presets, or if you wish to add the new preset to the list.
Claus
Posted on: 07 July 2017 by JMB
Posted on: 07 July 2017 by hungryhalibut
You can reorder them in the app as well so that radio 3 is the third light and 4 is the fourth one. We don't listen to radio 5 so the fifth light is radio 6.
Really helpful. thanks all.
Mike
