Will a Naim R-Com operate an ATC SCA2 preamp?
Posted by: vintageaxeman on 03 July 2017
Will a Naim R-Com operate an ATC SCA2 preamp? Anyone know if the codes are compatible?
Posted on: 03 July 2017 by Richard Dane
Does the ATC use the Philips RC5 remote codec?  If so, then the R-com or Narcom may well control some or all functions.  However, as RC5 has so many different codes and channels then you would have to try it out to be sure.
Posted on: 03 July 2017 by vintageaxeman
Thanks for your help Richard.
Yes it does seem to be RC5. So the R-Com is RC5 too? I'll get it tested and try to remember to report back!
Yes, Naim use RC5 for their remote control system.
Problem solved, I think. Cheers, Richard.
Posted on: 03 July 2017 by Huge
Even if the R-Com doesn't work, a Logitech Harmony can be programmed to control both Naim and ATC equipment.
Yup, I just like the ATC and Naim remotes!
Good news.  So I take it the R-com works with the ATC?
