Streaming to Naim uniti 1
Posted by: Lastglance on 13 July 2017
Hello, im looking to sign up to a family deal for streaming. Not sure which provider i'll go with yet. Question is - is there anyway i can stream spotify, amazon music etc to my Naim uniti v1 (hi fi corner advised its not upgradeable to Spotify for example). Any help would be appreciated. Ps. Currently have ripped all my music to PC and stream to the Uniti via UPNP input.
Posted on: 13 July 2017 by David Hendon
You could get your Uniti 1 upgraded by Naim who would put in a 192kHz board. Then you would be able to Spotify and Tidal as well as play 192kHz 24 bit HD downloads. Not sure what the present cost of that is. But they could tell you if you gave Naim support a ring.
best
Posted on: 13 July 2017 by JedT
Just had the new board put in mine (enjoying Tidal on my SU and wanted it on the second system) - the dealer put the new board in, think it was £320. I BELIEVE that some of the earliest Uniti 1's can't fit the new board but could be wrong.
Posted on: 13 July 2017 by Tony2011
As David says, your best option is to upgrade . The only thing you won't get is Bluetooth.
Give Darran of ClassA a ring. I'm pretty sure he'll be able to carry out the works.
Good luck.
Posted on: 13 July 2017 by Lastglance
Thanks for advice. Is it possible to cast spotify etc from phone / PC to the Uniti?
Posted on: 13 July 2017 by Mike A
Yes! I use an Airport Express connected to one of the optical inputs on the Uniti. This enables streaming of Spotify, Amazon Music etc from iPhone or iPad to the Uniti.  Clearly there is a trade-off in data rate/quality, but it's a robust solution.
Posted on: 13 July 2017 by Huge
Using a Chromecast Audio to cast music (using an optical link, via the optical input, to the DAC in the Uniti) is a lot cheaper than an Airport Express and AirPlay.
It's also uses a lossless compression and can cast 24/192kHz which Airplay can't do.
Ok - thanks all - some great advice here i'll be sure to follow up.
