ProAc D2 v Studio 118
Posted by: ThatsNotMyNaim on 30 July 2017
Borrowed some D2s. Expecting to be blown away.
Versus my ProAc Studio 118 they are:
- Deeper, tighter, chunkier in the bass.
- A bit more open in the mids/top end.
- Sharper treble but less extended. More restrained.
- More restricted and restrained in the mids. Like they need a good shaking.
- Much less expressive / less airey. Less exciting involving.
Fully run in demo model. Disappointed!
I didn't get on with PMC Twenty5.22 as they didn't seem to have much emotion. A bit functional sounding to my ears.
Tried some Neats, can't remember the model, floorstander single mid driver. Sounded boxy to me.
I get the feeling ATC will be droll and lacking in emotion. Just a hunch that one!
Have been told Spendor Classic series is quite good. But not heard.
What other speakers would people recommend at the size of the Studio 118/D2 that are expressive, dynamic, punchy and open. Not harsh or ear slicing though lile B&W / Dali.
Adam
Posted on: 30 July 2017 by badlands
I went from Proac to Dynaudio, and they tick all the boxes that you're looking for, try to listen to a well run in pair because the overall transformation from new is really incredible.
Take a listen to the Special Forty,  Excite X series, or if you're looking to spend a little less check out the Emit series.
They are expressive, dynamic, punchy, and have the finest tweeter on the planet!
Posted on: 31 July 2017 by crackie
Adam, are you locked into a standmount only speaker ? Because the D20R with the ribbon tweeter may sway you otherwise. Also ProAc have just released the DT8 within the last week or so and may be worth a look.
Posted on: 31 July 2017 by DrMark
I loved my Response D2s, but when I moved to my current location where the room was quite large I had issues  - more on the low end. I tried the ProAc sub, but I am not crazy about subs in general, and never did feel like I got it dialed in correctly; what seemed to work for rock/jazz just wasn't right for orchestral and other "classical" recordings. Were I to move to a smaller listening space, I would seriously consider another pair.
But in my current space I am running D28s, and am very pleased with those.
Posted on: 31 July 2017 by Iconoclast
I only heard the D2s with tube gear and they sounded great. I still own a pair of 115s and am looking towards the new RDB3s as an upgrade. Unfortunately Proac have become nearly impossible to demo where I live.
As Badlands mentioned you could give Dynaudio a try. I preferred them to Proac in a Simaudio Moon demo but did not get along with a pair of Excite X12 that I owned. Hooked up to a 65w Cambridge they sounded muffled with thumpy bass. With the exception of the fine tweeter I preferred a pair of $350 PSBs.
Posted on: 31 July 2017 by alanbass1
I would give ATC a try if only to confirm your preconceptions.
Posted on: 31 July 2017 by badlands
Yes, an amplifier with high current is definitely needed, otherwise they will sound like Iconoclast describes. Proac's also do better with high current amps, but are a little easier load on an amplifier than Dyn's.
Posted on: 31 July 2017 by ThatsNotMyNaim
badlands posted:
Sounds like a good bet to me. Worried they would be too smooth but I'll try them. Cheers
crackie posted:
I am. My room is too small 3mx4x for a standmounter at that size... but you are right... great speakers the D20R. Much better than the D2.
DrMark posted:
Fine speaked. The D2 are good don't get me wrong... just a bit cagey for my tastes.
alanbass1 posted:
Maybe I should. SCM19 would probably be the room max.
So I'll try some Dyns and ATC.
Looks like ProAc might be releasing a new Studio range soon also.
Posted on: 31 July 2017 by cat345
Many recording studios use ProAc Studio100's, SM100's and other makes for monitoring but not Response series.  There must be a reason for this.
cat345 posted:
Probably because they want speakers that are as flat as possible for hearing as faithfully as possible whats in the mix. Not necessarily what everybody wants.
Posted on: 03 August 2017 by ThatsNotMyNaim
cat345 posted:
The Response range are quality but they seem to dip in the mids to me.
Whereas studio range are seemingly flatter.
I don't know about the SM100 - I hear they are more revealing and critical than the consumer Studio range; 110/115/118.
Maybe it's worth looking into but they only come in horrid black.
Look like product have a new Studio consumer ranged coming.
Posted on: 03 August 2017 by cat345
ThatsNotMyNaim posted:
cat345 posted:
I think you can have the SM100's in cherry too, just like the Studio100.
Posted on: 04 August 2017 by ryder.
cat345 posted:
The Proac Studio SM100 in black looks better than the D2 in whatever finish including the premium finishes.
