atom, turntable, nano Phono V2
Posted by: wiwa on 01 August 2017
How to connect these on a Atom (it's for 22 of august)
thanks
Hi WIWA,
Rear of Atom shown below:
You have a single RCA input (shown above on lower RHS marked as Input~), that can be used to connect you Turntable using your Nano V2 phono Preamp.
On the Atom the input is selected from the Remote or via Naim App as Analogue 1.
You will need to download the Naim App from the appropiate app store (Apple / Android) - if you already have the app you will need to ensure that you have the latest update to operate the Atom. Then follow the Atom set up instructions on screen. All very straight forward. You will be giving an option of downloading the latest Atom firmware - you need to do this, before you move on throught the step up it takes about 5 mins to complete.
It would be my recommendation to have the Atom on a wired network connection rather than wifi - it just makes everything more stable.
Hope this helps
Simon
thanks for a great help
