Share folder is offline
Posted by: ngene on 01 August 2017
How do i get my share download folder online?
Posted on: 01 August 2017 by David Hendon
Reboot your router and restart your Unitiserve too is I suspect the answer, assuming that it has previously been online?
best
Posted on: 02 August 2017 by ChrisSU
Are you trying to view the folder on a computer? If so, the way to make it show up consistently depends on weather you're using a Mac or a PC. On a Mac, add the US drive as a 'startup item.' On a PC, map the drive.
Posted on: 02 August 2017 by ngene
ChrisSU posted:
No the folder is there and active but according to the share manager it is offline. I need to know how to get online on the PC.
Here is a picture. http://imgur.com/a/mvYul
Posted on: 02 August 2017 by Adam Zielinski
Some questions in order to be able to assist:
1. UnitiServe SSD with an internal drive?
2. What NAS?
Adam4
Posted on: 03 August 2017 by ngene
Adam Zielinski posted:
2. What NAS?
Adam4
No it is just a standard internal drive.
Posted on: 04 August 2017 by David Hendon
ChrisSU already gave you the answer. You have to map the downloads folder in your PC and it will appear on line to  your PC.
You can read any number of descriptions of how to map a folder or drive on a PC if you just google the question.
If you can't understand how to do it after reading some googled pages, then I think you would be best ringing Naim support who could if you wanted and ask them nicely log into your PC remotely and do it for you.
best
