Naim, the gift that just keeps giving
Posted by: ray sheldon on 02 August 2017
Did a bit of DIY over the weekend and made a few tweaks....
1. Replaced 2 x normal mains sockets with 2 MK unswitched. NDX&SN2 in first socket and US alone in second socket(spurred off from the first prior to new sockets).
2. Rearranged stack, top to bottom: NDX, US,SN2. (Previously SN and US other way round).
3. Got all 3 network cables off the floor and out of sight(almost) with the Netgear GS10 switch on the wall to the right of mains sockers with the 3 cables dropping to trunking that runs all the way along the top of the skirting to the router. A small cut in the trunking to allow 2 cables to go to the back of NDX&US. (Not sure if running network cables together in parralel is recommended or not). I know I wouldn't necessarily do that with mains or interconnects etc?
Cable dressing ok with no wires in contact with any others.
System on fraimlite to the right of speakers as it was before.
And the result...very nice indeed...
Top end smooth with more detail.
Nice improvement to mid bass.
Sounds cleaner and hearing detail I've not noticed before. I was surprised to hear notes in Jean Michel Jarre's 'Oxygene' that I've not noticed in 30+ years. If you know this album, part 2....the sound you make when you pull your index finger out of the side of your cheek 'pop' is jumping out of the speakers. I was blown away by the level of detail.
Will I add a HC to the SN as planned, unlikely. This combo blows me out of my seat?
Will I add a 250 to push the speakers further(I think the pmc25.23 would benefit as the SN2 is running out of steam when really pushed) unlikely, there seems to be as much power that one would need before destroying your ear drums.
Those little tweaks really make a difference and I think I'm happy here for the foreseeable....except that I'm wondering if a more revealing speaker cable would lift the mid a little more without introducing unwanted brightness. I won't be jumping to Lumia just yet. BTW, already have the Lumia IC.
