Hicap dr
Posted by: Johnny5 on 03 August 2017
Does anybody know the correct way to connect the hicap dr to the sn2 their is four sockets when  looking at the back from the left their is 3...  4 pin socket and and 1... 5 pin at the end.I am new to naim.
Posted on: 03 August 2017 by Richard Dane
DIN5 to the Supernait via SNAIC5, and then DIN4 to the Supernait via SNAIC4 - you can use any of the three available but usually best to use the closest to the DIN5 to keep signal lengths as short as possible.  Make sure you get the SNAICs the right way around with banded ends as shown in the manual pictures.
Posted on: 03 August 2017 by Johnny5
Great thanks
Yes the snaic banded go from the hi cap end to sn or sn to hicap.
SNAIC5 - band nearest the Supernait
SNAIC4 - band nearest the Hicap
Posted on: 03 August 2017 by Jumping Jack
There is a very useful 'connection guide' that used to be on the website. I can't find it on the website anymore, but it is still accessible by googling 'naim connection guide'...
It should all be illustrated in the manual.
Great stuff I have it sorted it improves the SN2 by a mile sound is more separation much wider soundstage but I am using pmc 25/23 which are amazing speakers.
