Why does SL DIN to XLR not have mechanical alignment on the DIN
Posted by: Filipe on 04 August 2017
[@mention:1566878603942595]
Just to explain, my twin brain brawn racks make it difficult to plug into the SuperCap DR except by taking records out of the left hand racks and going round the left hand rear of the SC. The 300 amp is pulled out to enable the connections to be made. I note the required orientation and push them in. However, on powering up the 300DR PS it goes into oscillation every time with the volume on 0. Reverted to the Witch Hat IC which has the mechanical alignment and everything is ok.
I'm assuming the 300 oscillation means there is an open circuit. Would you agree? I could take the right hand rack stack apart from the top down, but why no mechanical alignment, or has someone damaged these loan cables loaned to my dealer by Naim (thank you)?
Phil
