iOS apps keep not finding rooms
Posted by: Red Ticker on 06 August 2017
I have 4 UnitiQute2s wired into my home network controlled using the iOS app running on iPods which connect to the network over WiFi. Since the update to the latest app version 5.7.3 I frequently get "Finding Rooms" and then "No rooms found". Previously they just used to connect straight to the last UnitQute2 they were connected too. When I check on my router, or with Fing, the UnitiQute2s are visible on the network and entering the IP address into my web browser connects straight to the UnitiQute2.
This is what I get when I connect:
| Device Name: | Study |
| Current Profile Name: | Profile1 |
| Mac Address: | 00:11:F6:A9:A2:FA |
| Current IBSS State: | false |
| Current SSID: | not available |
| Current Encryption State: | not available |
| Current IP Address: | 192.168.0.25 |
| Current Netmask: | 255.255.255.0 |
| Current Default Gateway: | 192.168.0.1 |
| Current DNS1: | 192.168.0.1 |
| Current DNS2: | 0.0.0.0 |
| Current DHCP State: | Got IP address from a DHCP server |
| Current Proxy Server State: | off |
| Current Proxy Server: | |
| Current Proxy Server Port: | 0 |
and
| Connection Status: | connected, BSS |
| Signal Strength: | not available |
| Wireless Channel: | not available |
| Firmware Date: | 2015-09-15 |
| Firmware Version: | 2.0.68.13731 |
I have turned off and reset the router, network switches, and the iPods as well as quitting and restarting the apps, but the problem persists.
Any ideas?
Martin
