connection
Posted by: pino on 08 August 2017
Hello to all
I wanted a little help: how do you connect the Naim HeadLine rca version to naim nac 282?
thank you so much
From Naim's own web site:
"Fitted with a captive lead, the HeadLine takes its signal from the tape socket of any of our preamplifiers, except the NAC 152 XS. It has its own volume control and is designed to be very, very quiet. It has the ability to drive most headphones to an adequate level (i.e. loud) with low distortion.
Headphones tend to be highly revealing of both noise and distortion, so we have expended a great deal of effort getting these parameters to extremely low levels.
The HeadLine needs to be used with an external power supply such as the NAPSC. If using a FlatCap XS, HiCap or SuperCap you will also need a special interconnect, the SLIC."
Pino,
the RCA version is the wrong version for use with the NAC282 - you need the standard DIN version. The factory service dept. may well be able to re-terminate it for you though, or else your Naim dealer or distributor may be able to do so.
Of course, as Blythe quotes above, you will need a power supply to power the Headline.
