Atom + Mu-so multi room problems
Posted by: Hemmendorff on 09 August 2017
So, after 9 months of waiting i finally recieved my pre-ordered Naim Uniti Atom. Setup has been fine and all network, updates and services seem to be in place.
However something is weird about the multiroom functionality when i'm trying to pair it with my Mu-so. Using the naim app on my iphone, both devices show up as "rooms" in the app start page. But when i'm playing from spotify/radio/etc, and click the little symbol beside the volume bar, i can't find the Mu-so. However if i go out to the Rooms page in the app and select the Mu-so as the active device, i can play on the Mu-so AND find the Atom in the multiroom menu.
To try to clarify:
- The app finds both devices when looking in the Rooms screen
- When the mu-so is the active device, the Atom pops up in the multiroom menu
- When the Atom is the active device, it cannot find the Mu-so in the multiroom menu
But yeah, i CAN play on the mu-so and select the Atom as an additional speaker in the multiroom menu. But it's still wonky. It usually doesn't work directly (it says 'Room Atom did not respond') but on the second attempt it usually works. Then they're playing together nicely but after 1 minute or so the Atom just shuts off. I haven't timed it but it's very consistent, it loses the connection every time and it's always after around 1 minute of multiroom playing.
So, any advice? Both machines are running the latest firmware, have been restarted numerous times and are on the same wifi.
Would love to have this resolved since the multiroom possibility were key when going with naim's streaming stuff in the first place.
Thanks!
