App update.
Posted by: steven2907 on 11 August 2017
Just updated and everything seems fine
Fine in what respect?
No sign of core 1.5 firmware tho yet
It works fine although it is slow at bringing sources from the main menu. I liked the sub menu, but is is only available to me when opening the app for the first time after its deletion and downloading. ![]()
Chag -
Fine as in upon opening the app there's still a slight delay in finding rooms and opening controllability, but still no where as quick and reliable as it was before all the updates started, maybe it works better on the newer models
On both my Musos it is still just as slow.
Why bother releasing an App update when it hasn't really fixed any of the main issues.
No point for me playing with this app until the 1.5 firmware for core comes out. I believe it will fix the SMB issues, but i dont know if it fixes the disc formatting issues. I doubt if it has the metadata editing required for classical music, or has any of the more structural issues like backup/restore/import/storage/rip confidence fixed, let alone support for disabled users.
September 1st looms in the diary.
Is there any point to get this update? Is it an improvement over 5.7.3?
CSI_Basel posted:Is there any point to get this update? Is it an improvement over 5.7.3?
Yes
Some improvement, but in my system I noticed instability in that it flicked between states with no input from me, cycling between input selection screen, (I was trying to use USB input) and album list. This issues was a New one on me.
ROOG posted:Some improvement, but in my system I noticed instability in that it flicked between states with no input from me, cycling between input selection screen, (I was trying to use USB input) and album list. This issues was a New one on me.
Hi Roog (or is it Fillmore) I've found some issues can be helped by a completely clean app install. I suspect installing over an old revision app can carry over or make new problems, it shouldn't, but I'm not convinced that is so. I always delete the app & 'force restart' the iPad/Phone - this clears the RAM - then re-install the app. It might not fix your problems (that I don't recognise with my system BTW) it only takes a few minutes, so whats to loose.
Thanks Mike-B... your above suggestion has made a big difference to my app usability. Highly recommended
