15% improvement
Posted by: stuart on 17 August 2017
Over the last few weeks I have noticed a real step up in performance in my system. Without going g into too much detail the bottom line is that everything is better. High frequencies are less harsh and I am actually struggling to get bass boom on the usually difficult tracks even at high volume. I think this may be down to three reasons. I thought I would post in the hope that it may help others to fine tune their systems.
Firstly I moved speakers further apart so the drivers are now 7 feet apart. My listening distance is 7 feet from the speakers. I also changed from slightly toed in to firing straight forward.
Secondly and I'm not sure how significant this is, I have covered the corner leather sofa with two thick throws, one of which corresponds roughly to the first reflection point of one speaker. The other is roughly behind my listening position.
Thirdly, I have powered down my system several times lately and noticed that after re-plugging in the mains cables the sound was noticeably better. I had a separate CU fitted last year with 3 double unswitched MK sockets and plugged everything in,not really paying attention to the order. I suspect that I have plugged the components back in a different order but need to work out which is which - I have used masking tape on mains cables so I re-plug them back in the right order when I power down again. I will trace each cable back to component and work out what goes where at the weekend.
Could the plug order make a difference to sound quality? I am only using 4 sockets - the top two doubles - the bottom double is unused.
