cable hi line
Posted by: pino on 24 August 2017
Hello to all
Reassembling my hifi system I saw that the hiline cable has a loose ring.
Is it broken?
thanks a lot to everyone
Posted on: 24 August 2017 by Bob the Builder
No not completely when I had a HiLine a similar thing happened and it very gently clicked back but if it has come completely free I would seek proper advice.
Posted on: 24 August 2017 by northpole
If you can, have a good look to check if any articulation has not just loosened a ring, but also affected the connection of one of the wires inside.  Hopefully none of the lugs are damaged and the loose ring should click back in position.  Handle with kid gloves though as these things are as delicate as a very delicate thing!  As Bob advised, any doubts, you'd be well advised to take it back to your dealer to inspect.
Peter
