Added new stations to ND5 XS not connecting
Posted by: orestpsychi on 29 August 2017
Added new radio stations to my nd5 xs using naim vtuner, the added stations show on the ND5 XS screen but won't connect.  It says "can't play station unavailable" and then goes to
"no station".  What have I done wrong? do i need to use Non-DHCP?  Help please.  The stations are Calm Radio subscription stations.
Posted on: 29 August 2017 by Adam Zielinski
Can you stream other radio stations?
Posted on: 29 August 2017 by orestpsychi
Yes I can stream new stations and every other station except the added stations
Posted on: 30 August 2017 by Adam Zielinski
If the other sttions work fine, than your netowrk connection is fine.
You need to re-visit the process of adding the stations - this is done either via the front screen / remote or via the Naim app.
Posted on: 30 August 2017 by Kacper
two weeks ago I have added Slam FM Dutch radio station using two URL addresses, one of those two URL's also didn't work.
