Unitilite showing folder as (Empty), PC shows files are in there.
Posted by: coachpotato on 08 September 2017
I recently copied 2 cd's of .wav files to my ReadyNAS 102 storage from my PC using Exact Audio Copy. To keep things in order, I made a folder of the named CD, with subfolders called Disc 1 and Disc 2. After EAC had finished copying, I checked the files were there on the NAS, which they were. I restarted the NAS and, later on, accessed the folder(s) through the menu system on my Unitilite. It showed the files listed for Disc 1, but the Disc 2 folder as (Empty).
I rechecked the folders through my PC, both folders showed the existence of the files and in numerical order. I tried using EAC again to copy the files for Disc 2, same result. The discs are not copies, also further discs are also producing the same result.
Any help would be appreciated, thanks!
