The slightest tweak
Posted by: overprint on 13 September 2017
Thought I'd share how a slight tweak over the weekend has made a lovely difference to the sound I'm hearing - but sure why really. I removed a grandfather clock from the corner of the living room which backed onto the same wall as the speakers (SL2s). Pushed a normal lounge armchair into the corner (cloth not leather) so it now sits 45 degrees across the corner rather than parallel or perpendicular to the walls. No other changes.
Very noticeable difference in bass extension (lower lows and slightly firmer overall) and an obvious improvement in separation of instruments with each more clearly defined in the mix.
Anyone care to suggest why? Was the hollow carcass of the grandfather clock causing interference? Glass face acting as a reflector or is having a soft, armchair in the corner acting as a bass trap? Either way well chuffed with the improvements. My SL2s never cease to amaze me how much I can get from them.
