How Do You Get Your SuperLumina DIN/XLR Off The Floor?
Posted by: nigelb on 14 September 2017
I am getting a SL DIN/XLR tomorrow and at 1.5m it is way too long for those of us with a single stack of Fraim to be off the floor when fitted. My Supercap and 250 are on the bottom two shelves of my Fraim (where they will stay), so much of the SL DIN/XLR's length will be resting on the floor which I am led to believe will be rather detrimental to SQ.
I know HH has successfully tied a very loose knot in his SL DIN/XLR and that keeps his off the floor because his 272 is towards the top of his rack. Even with a loose tie, I am pretty sure mine will still be on the floor. I currently have my Witch Hat DIN/XLR resting on a foam pad. However I was wondering if others with the same issue have found a solution which is optimal from an SQ point of view.
