New IOS 11 update. Check before you click...
Posted by: Tony2011 on 19 September 2017
Some of your old and favourite apps(32bit) are not compatible with the new(64 bit) update and will not be supported by Apple.
To check if your apps will be supported go to Settings>>General>>About>>Applications and you will see a list of the ones which currently have no updates available.
I'm sure Naim are on the case but you may have some old apps lurking in the background.
Check them out...
Posted on: 21 September 2017 by trickydickie
There is also an issue whereby email is broken if you use Exchange or Office 365.  See https://www.theinquirer.net/in...5-and-exchange-users
I've installed Outlook to get around this but it beggars belief that such a fundamental bug slipped through.
We really shouldn't beat Naim up too much for their minor bugs in their app when somebody as large and well resourced as Apple can get this so wrong.
Posted on: 22 September 2017 by Mike Hughes
Not had any issue with Exchange. Big issues for me are the new keyboard. Nice idea badly executed with gray. That and the appalling behaviour of the Control Centre where it appears that turning mobile data, Bluetooth or wireless off no longer actually turns them off. Worse stil, if I’m on 4G and go to Airplane Mode and come out it turns on Bluetooth wireless without asking. Unimpressed.
