iOS 11...
Posted by: gert on 19 September 2017
... did someone dare to upgrade already?
We're all waiting for you....
I’ve run it throughout the beta program and now the release copy, no issues experienced with naim app throughout
Thank you very much, good to know that naim is working. I anyway will wait a few days before upgrading. But if I hear only good reports, this will reduce the number of days ![]()
Reading this using IOS 11. No issues ....yet....
N-Serve and Naim app both working well on iOS11 on my iPad.
Tony2011 posted a useful instruction on how to tell what apps won’t work in iOS11;
https://forums.naimaudio.com/to...eck-before-you-click
ATB. G.
iOS 11 working fine on both iPhone 7+ and iPad (Pro: 9.7 inch)—and no problems with the Naim app.
Stephen
Hi
Using a 9.7in iPad Pro and my first impressions of iOS 11 are excellent, particularly for multitasking - slide-over and split-screen. Unfortunately though Naim have made fixing the crashes in slide-over in landscape mode a low priority even for iOS 10. In iOS 11 slide-over doesn’t even work properly in portrait mode.
While in Safari for example, you can drag up the bar of favourite and recently-used apps. From there, the Naim app can be dragged over Safari to get the new version of slide-over but there is no line in the header to allow you to move it round the screen or even off the screen. In fact, I ended up rotating the iPad to landscape so the Naim app to crash to get rid of it.
Very disappointing to say the least.
Roger
PS not heard anything yet about release of Airplay 2 support (I have an Atom) even though Naim said they would be doing this in parallel with Apple’s release timing. Mind you, we still do not have Multiroom working with the Mu-so (I have one and a Qb) and Naim will not be supporting Airplay 2 in these systems either.
No issues here on my iPhone. I don't/can't use iOS 11 on the device that's used to host the Naim app, so have no experience with that.
After upgrading to iOS 11 on my iPad I lost visibility of my Synology DS216 NAS. I could still access it from the front panel of the NDX and on my Android phone so tried un-installing and reinstalling the Naim App on the iPad. Now it works fine...
I updated to iOS11 and Naim app v5.8 on my ipad pro.
v5.8 on my ipad is not reading my playlists properly. The playlist is there but songs are missing or incomplete.
On my iphone. It's still running iOS10 and Naim app v5.7. No issues at all.
Anyone has similar issues?
IOS 11 here. No issue with the NAIM app ...but... some apps don’t work, including “PlatterSpeed” which I was using to check my TT wow and flutter over the weekend :-( ...but I reckon this is irrelevant for the “streaming” forum
Since updating my iPad mini 2 to IOS11 I ha e experienced repeated problem of not being able find rooms which can only be resolved by restating the iPad. I have a su and a core on wired network. Has anyone having similar problems. Have updated the app t 5.81 and restarted the router. But still reoccurs.
I have an iPad mini but haven't updated it recently, so.... Maybe I'll wait a while longer!
Upgraded yesterday my iPad mini no issues so far, loving the new keyboard setup...
I have upgraded my ipad mini 2 to iOS11. And so far everything works fine. (The keyboard swipe down feature is really fine.)
But in most cases I am using the lumin app to stream qobuz to my uniti via the BubbleUPnPServer. So maybe I just have not met the issue yet.
There’s something a bit odd going on with the Net Analyzer app. It shows a warning about not showing MAC addresses in iOS11. Bizarrely, my MacBook shows up twice, with two different IP addresses.
ChrisSU posted:There’s something a bit odd going on with the Net Analyzer app. It shows a warning about not showing MAC addresses in iOS11. Bizarrely, my MacBook shows up twice, with two different IP addresses.
I don't have the duplication problem with Net Analyzer (family MacBook Pros, iPads, etc., all singular) but the flagged missing MAC addresses is a pain. (I appreciate it's an iOS 11 "thing". It does make naming devices on the home network something of a pain.)
Stephen
I’m now seeing my Atom listed twice in Net Analyzer, but this can’t be an iOS11 issue, as it also shows on my old iPad running iOS9. Perhaps my DHCP server is misbehaving.
