Cable length Nova
Posted by: Oskar on 03 October 2017
I have ordered a Unity Nova with Naca5 cables.
I only need 2 meters on each side and my question is if you also on the Nova need to have at least 3.5 m length on the Naca5 speaker cable?
/Oskar
Posted on: 03 October 2017 by Gazza
This is not sensitive to cables like the older black boxes
Posted on: 03 October 2017 by Oskar
Thanks for your reply GAZZA!
Posted on: 03 October 2017 by Mike-B
Its tempting to reply "what does the manual say"  ............ the answer to that is   "what manual"
Posted on: 03 October 2017 by hungryhalibut
Longer ones sound better, and ideally the Nova will be off to one side so there is nothing between the speakers. I’d stick with 3.5m, if only because 2m lengths will be virtually impossible to sell, should you fancy a change at some point.
Posted on: 03 October 2017 by ChrisSU
The 'quick start guide' makes no recommendation on cable length. The Nova 'support' pages recommend NACA5, but again, no mention of length. At least, if there is, I can't find it, but this is by far the clumsiest web resource I've ever tried to navigate my way through, and should, in my opinion, be released as a simple PDF.
Posted on: 03 October 2017 by tonycurran1
I agree 2 m will be hard to move on
i would go for the 3.5 enjoy your Nova.
You should ask your dealer, or Naim support directly - I can see no point in buying more than you need if the 3.5m minimum recommendation doesn't apply to the new range. It's very stiff and awkward to handle, so hiding any excess can be tricky, and you would be wasting money.
Thanks for your answers.
I have 2*5m that I used for my Supernait 2 and that is way to long for my current setup so cutting it will not be an issue. Just wondering if the construction of the Nova limits me to longer cables.
Oskar posted:
We don't know! That's the honest answer - you should ask Naim, as we will only confuse you....
Just put the Nova where the Supernait was, and they will be the right length.
