Uniti Atom and DSF Files
Posted by: Riccardo Luchetti on 09 October 2017
Hi to everybody.
A little question: i have a Uniti Atom that recognizes DSF files only from an USB HD.
The DSF files aren't recognized from a NAS linked by an ethernet cable.
Any solution?
Thank you
Richard
Posted on: 09 October 2017 by hungryhalibut
Sounds like an issue with the upnp server. What is it?
Posted on: 09 October 2017 by Simon-in-Suffolk
Hi Richard, I think you’ll find your UPnP media server needs to send the DSD files encoded as DoP.. which effectively means the DSD file is encoded into a file construct container used for WAV. Can your UPnP media server handle DSD files?... can you see the DSD files in the Naim app? If not you need to use a different media server package like MinimServer or Asset.
Simon
Posted on: 11 October 2017 by Obsydian
Depend - sorry somewhat vague but i had 64/128/256 versions, Naim brochure mentioned support only for 64
Posted on: 11 October 2017 by ChrisSU
Obsydian posted:
The Naim streamers support 64 and 128.
Posted on: 12 October 2017 by Simon-in-Suffolk
The Naim streamers support 64 via Ethernet
Posted on: 12 October 2017 by Mike-B
............   the new Uniti players (the OP question) show support for DSD64 & 128 in the 'Audio Formats' spec, which I assume is via Ethernet (UPnP/NAS),    as in the 'Audio Inputs' section [Optical, Coaxial RCA & HDMI only] it shows RCA up to DoP 64Fs
Posted on: 12 October 2017 by DomTomLondon
I've encountered the same issue while trying to play DSF files from my Qnap using MinimServe.
The Atom I had at the time would not play them. While the SuperUniti has no problem at all. Strange...
Never worked out what the issue could be. But I mentioned it to naim support over 3months ago.
Posted on: 15 October 2017 by Leon Wadsworth
My nova plays DSD128 over Wi-fi no issues.
