RP8; VTA, record thickness and cartridge choice?
Posted by: Judge on 09 October 2017
On my current turntable I use the original 3mm thick rubber mat for my normal vinyl, but for the 180gm stuff I use a 2mm rubber/cork mat. Both sound fine but the main idea is that because the heavier records are thicker, the thinner mat provides enough correction for VTA. I could actually adjust the arm too, but fortunately this works really well.
I like the concept behind Rega’s Turntables and the simple design, but I’m not sure how they cope with varying record thicknesses. I understand there is no VTA adjustment on the arm either.
In a number of photos of forum member systems a Rega seems to feature and so I was curious what users have found when playing different thickness records. A lot about vinyl replay is some form of [optimised] compromise, so does it even matter?
Also, if the is no VTA adjustment, how do you accommodate different cartridge choice from the Rega options?
Thanks.
