Naim NAP282 input question
Posted by: NJB on 10 October 2017
My 282 is configured to use the rca sockets through the cd input. This is how I currently use it. I have now bought a new interconnect with a 5 pin DIN plug and want to do a side by side comparison with the old cable. If I understand the 282 manual correctly, when the 282 is programmed to use the rca inputs then the corresponding DIN socket is isolated. Therefore, swapping the cables through the same input (cd) will take a few minutes while I run through the programming mode etc. Are there any differences between the cd, tuner, tape etc inputs? If there are, then it would not be a very successful comparison! If not, it will be far easier to do.
