Dedicated Mains Spur
Posted by: Blackmorec on 12 October 2017
Much discussed topic, I have recently upgraded the mains spur for my hi-fi room, changing both the cable and the wall sockets. The difference it made was not subtle. Anyone who is suffering from grainy or harsh sound should IMHO look at their mains supply before changing or upgrading other aspects of their system.
I spent quite a bit on money on this latest upgrade but I’m absolutely certain that the same amount of money spent elsewhere in my system would not bring anything like the same degree of fundamental improvement.
My latest mains supply comprises the following:
- Dedicated consumer unit with 100A isolation switch.
- AHP Klangmodul fuse holders and fuses
- Acrolink 7N-P4030 II 99.99999% purity 4m2 3 core Stressfree Cable (foil shielded Polyolefin insulated, low dielectric constant)
- Furutech FP-1363D Gold wall sockets
The first thing you notice is how tightly the wall socket grips the plugs...the next is the huge improvement wrought even before any burn-in. Depth, focus, purity, grainlessness, intensity, impact, detail, dynamics and micro-dynamics, naturalness, transparency. I’ve yet to buy any new component that brings so many fundamental, across the board improvements. I believe that conductor composition is far, far more important than gauge. The cable I had installed is rated 50A....more than enough for any hi-fi. Bog standard T&E, even in heavier gauges will not give you anything like the same results....again IMHO (and my experience).
