Fraim height confirmation
Posted by: MangoMonkey on 14 October 2017
Can't tell 100% looking at the dimensions online - wondering if anyone can confirm this:
Two medium fraim shelves stacked on a base level would line up with three standard sized fraim shelves.
One Tall fraim shelf will line up with two standard sized fraim shelf.
Thanks!
I'm looking at reconfiguring brain sized of the fraim, hence the questions. Currently, the system looks pretty wierd due to too many spacers shelves. Looking at options...
Posted on: 14 October 2017 by Richard Dane
Yup, correct.
Posted on: 14 October 2017 by MangoMonkey
Thanks!
Now the question becomes:
a) is it worth the churn? I've currently got (top to bottom): NDS/552/Space/300, and can also run NDS/space/552/space/300, the latter looking kinda wierd.
Not sure whether doing NDS/552/300 with medium shelves would be a step backwards from the either of the above configs - best case it would be a wash..  Hoping it would be better than the former and as good as the latter.
Maybe $$ better spent on interconnects?
Posted on: 15 October 2017 by DaveBk
I have 2 stacks of medium Fraim - NDS, 552,300, empty except a small 4 port switch. I top this off with a single medium Fraim lite which protects the NDS and in my opinion improves the aesthetics. This was the best option my dealer and I could come up with.
