Uniti Core Metadata
Posted by: Frances on 14 October 2017
I've just bought a Uniti Core and have started ripping my classical CD collection.  For at least half of the them the metadata it finds is incomplete, wrong or unhelpful (e.g. "The CBSO Years Volume 23" rather than "Haydn The Creation Disc 1").  The second CD of a box set often has data unrelated to the first CD.
In particular, the composer is frequently missing.
My dealer who set it all up for me showed me how to change the album title, artist and genre, but I can't seem to change or add the composer.
Browsing this forum implies this is not possible.  I find that so hard to believe I'm posting possibly the same question again: is it really not possible to edit or add the composer?  If so, what do other people do?  I have a large collection of CDs and it is just intuitive for me to find the piece I want to listen to by starting with the composer.
Incidental second question: I'm setting up playlists for pieces that go over multiple CDs (such as The Creation) but a Playlist seems to have a title and no other data.  I assume I'm not missing anything, and I'd be interested to know if there are other, better, ways of dealing with such things?
Sorry if this is just repeating an existing question yet again.
Posted on: 14 October 2017 by Frances
p.s. The best one is Mahler 3, CD 1 has come up as "The Original Pure Thoughts - Holy See, The"
Posted on: 14 October 2017 by nbpf
Frances posted:
The UPnP server of the Uniti Core offers very poor support for classical music. If you are interested in classical music, you can probaly use the Core as a storage device and run MinimServer or any other server that well supports classical music on a Raspberry Pi connected to your LAN.
Posted on: 14 October 2017 by French Rooster
Frances posted:
you can go on the topic «  search «  part of this forum, the same kind of questions had been answered.  David Hendon can help you too....
French Rooster posted:
Frances posted:
See https://forums.naimaudio.com/to...uestions-and-answers, in particular question 2, 4 and 5. Best, nbpf
Posted on: 15 October 2017 by David Hendon
Welcome to the strange world of Naim UnitiCore metadata editing.!
Unfortunately you can't currently edit the composer (nor conductor) on the Core. Naim have promised to fix this in due course. I believe they are looking at the next Core firmware update at the end of October but the firmware revision isn't out in beta yet so I don't know what it will and won't fix.
The problem you mention of classical CDs showing up as part of a different set is a very well known limitation, although it did seem to catch Naim by surprise at launch, which suggests that there aren't too many classical music fans in the Naim software development team or the staff beta test team, come to that.
You can sometimes fix it by using a different metadata source. You do this by going into metadata editing, hit the "lookup metadata" link and then when it has returned the answers, selecting each tab in turn to see whether one is better than the other. If not then you have to edit what you can now and wait for Naim to make it better in the future. Even so it can be a challenge to get all the discs of a set to show up together in album view and in the right order. It's best to do this at the time you rip because otherwise the task may overwhelm you! Also after a rip sometimes it is nearly impossible to find where it has gone to and that is where the "Newest CD" option is very helpful because your Mahler symphony which now languishes as a piece of religious music, presumably with "Various" as the composer might never otherwise come to light again!
I'm sorry I can't help with playlists. I don't use them and have never bothered to find out how they are supposed to work. But others can advise you on that.
best
Posted on: 15 October 2017 by Richard Morris
From the linked thread above, mid-June:
"...composer, conductor and genre are planned to be added shortly and other indexing fields can be added as required"
Posted on: 15 October 2017 by nbpf
Richard Morris posted:
Instead of adding indexes that not every user might need or want, it would be better for users to be able to add whatever index they wish to populate. This is how MinimServer works and it works very well indeed. For classical music, for instance, I very much use "composer", "work", "ensemble", "conductor" and "form" (populated by values like "piano sonate", "symphony", "serenade", "string quartet", etc.). But for other genres I use other indexes. And other users will have yet other ways of organizing their music collections. Just give them a simple means of doing so. Best, nbpf
Posted on: 15 October 2017 by French Rooster
nbpf posted:
but can you use minimserver with the core?   i doubt...
You are right. You can't use anything with the Core except what Naim installed, which isn't Minimserver.
The Core is a buy it and use it device for people who don't want to mix fighting with computers with listening to music.
I can do all those computer things if I want to, and I do for work, but I bought a Core to make my music listening computer-fighting free and if someone were to steal my Core in the night, I would use the insurance money to buy another one.
Best
nbpf posted:
No, you cannot. That's one of the reasons why I have not bought a Core. On the other hand, if one wants great support for classical music, one can probably still use the Core and rely on MinimServer running on a networked device (a Raspberry Pi is more than enough and costs about 40 EUR) to serve the data to networked streamers. At least until Naim has improved support for metadata in their UPnP server. Best, nbpf
Posted on: 15 October 2017 by CEverett
I believe that the metadata issue chiefly affects ripped CDs which go to the Music Folder.  If I understand this correctly, I believe that you can use your computer's file management software, such as Apple's Finder or Windows Explorer, to find the ripped files in the Music Folder.  You can then move them to the Downloads Folder, where you can use metadata editing software (like metadatics (sp?) or dbPoweramp (perhaps?)) to make the appropriate metadata tag editing/creation.  Then you can play the properly "imagined*" (edited) music from the Downloads Folder.
Those with greater experience with the Core, please correct me if I am wrong.
*From Naim's Uniti and Core promotional materials:  "Your Music Collection Reimagined:  Uniti Core offers infinite possibilities, however you want to listen to your music." (So long as your Music Collection contains no Classical or Compilation CDs.)
Sorry, Naim, but I couldn't resist the temptation to make a gentle dig at your Uniti/Core promo materials regarding the metadata issue.  Outside of the metadata issue, I've heard the Core compared to the Unitiserve and to a NAS with Minimserver, and it sounds fantastic.
CEverett posted:
According to Phil Harris you are wrong, see his answer to question #2 in https://forums.naimaudio.com/to...uestions-and-answers. Perhaps Naim will add support for indexes typically used for classical music in an upcoming software upgrade of their UPnP server?
Posted on: 16 October 2017 by jon h
If the "solution" is to rip the CD on the Core, then move the file somewhere else and edit it, you might as well just rip the CD somewhere else and do the job there.
Posted on: 16 October 2017 by David Hendon
CEverett posted:
This is right except that Naim always say that messing around with files in the Music folders risks breaking the indexing, so I would suggest that the best way is to copy the files from the Music folder to the downloads folder and then use the app to delete the version still in the Music folder.
best
Phil doesn't say you can't do it. In fact he says you can do it if you want to. But it's not officially "sanctioned".
But copying the files across (as he pretty well suggests) and then deleting the original using Naim's app (which he doesn't mention but is of course completely fine) is the way to do it.
best
Posted on: 16 October 2017 by nbpf
David Hendon posted:
best
One can edit the metadata in the downloads folder as one wishes, of course. But Phil's asnwer to my question Nr. 2 suggests that changes to "composer", "conductor" and "genre" are not going to be honoured by the Core's UPnP server. I understand this as meaning that the Core's UPnP server simply ignores these indexes, but I do not have a Core to double check. Perhaps you can give it a try and confirm or confute my understanding? Best, nbpf
Posted on: 16 October 2017 by Frances
Best
Yes, that's exactly why I bought it (except I don't do those things for work).  I just want to rip all my CDs onto it and listen to them when I want to.  I bought a streamer at the same time (not Naim so I'm keeping quiet about it here).
So I don't really want to set up a whole separate server and cataloging process - it's not the cost, it's the hassle.  Having had my suspicion confirmed, I guess I'll just wait for a NAIM update.
The good news is that it does sound great!
nbpf posted:
The Core doesn't ignore the Composer, in that I can list or select my music by composer (for pieces where it has been identified) but I can't add or edit the metadata.
It's truly weird. I've been involved in some IT projects over the years, and why you would allow editing of some bits of metadata but not others is just strange as far as I'm concerned - I would have thought it was more work to restrict the editing ability!
Frances posted:
nbpf posted:
I do not understand. Once your files are in the download folder (not the music folder) they shoudl be read/write visible across your network and you should be able to edit them using a third-party software of your choice. Any decent metadata editing software will allow you to edit the values associated to Composer, Conductor, Genre, etc.
Thus, the relevant question is then whether the Core's UPnP server will index those fields or not. My understanding (following Phil's answer to question 2 in https://forums.naimaudio.com/to...uestions-and-answers) is that the answer is negative but I cannot check it out since I do not have a Core.
Given that you have a Core, just try to edit the Composer, Conductor, Genre field of a file in the download folder and you will find out whether I am correct or not. In you do so, please let me know.
I have been away from my Core today so not able to engage with this discussion. I think the you can edit whatever you like in the Downloads folder, but the upnp server in the Core and the Naim app will only allow you to access certain fields and to edit metadata in only some of them. As we know we are promised some improvements but these have not manifested themselves yet.
I think the Core does index genre, composer and conductor, but you can't edit them in the app yet, so the Core will respect edits of genre, conductor or composer in the downloads folder but those have to coexist with whatever sense or nonsense the metadata lookup databases the Core consults come up with for those fields for CD rips.
best
best
Why should internet metadata databases have any impact on the values that have been set by users for the files in the downloads folder? That would make little sense! At this point I am not anymore sure that I do understand how the Core's UPnP server handles the metadata of the files in the downloads folder. At least, it seems that I am not the only one in this situation. I wonder if anyone at Naim could bring some light on this issue. Someone must somehow know how the product that they sell does actually work. Until then, I can only refer to Phil's answer to my question #2 on https://forums.naimaudio.com/to...uestions-and-answers. It clearly states that " ...composer, conductor and genre are planned to be added shortly and other indexing fields can be added as required.". To me, this suggests that composer, conductor and genre are currently not accouted for. But I am not a native speaker and I might have misunderstood what he actually meant to say, of course. Good night, nbpf
You should read my answer again. I am saying the opposite of what you seem to think I am saying.....
best
best
I think that I understand what you are saying, my understanding of how the Core works is mainly based on your reports.
The crucial question for the OP here, however, is whether the Core's UPnP server will present to the Naim app the changes that one makes to the Composer, Conductor and Genre fields of files in the downloads folder or not. If the answer to this question is positive, the OP obviously has a simple means of solving his issue: just transfer all the files to the downloads folder and edit their metadata with a third-party app there. If the Core's UPnP server does not index the Composer, Conductor and Genre fields of the files in the downloads folder, however, such edits will have no effect.
Phil's answer to my question Nr. 2 in the above mentioned thread suggests (to me) that the latter is the case. You say that you think that the Core's UPnP server does in fact honour edits of Composer, Conductor and Genre in the downloads folder. This would be a very good new for many Core users, I guess.
A simple test could provide a definite answer, but I cannot run such test because I do not have a Core! Perhaps you can try editing the values of Composer, Conductor and Genre for a single file in the downloads folder and check whether the Core's UPnP server honours the edits or not. Then the question would be settled.
Posted on: 17 October 2017 by David Hendon
Just adding to the above, you can currently search on composer, conductor or genre in the app and you will get a list of results which includes your correctly edited files in the downloads folder and  the ripped files in the Music folder, which may or may not be correctly labelled. At present you cannot edit these field in the Music folder but as you point out, Phil has confirmed that editing of these fields will be added shortly. When Phil says that other fields "can be added as required",  we don't know yet whether this means that Naim can add them as required or that an end user can add them as required, but I suspect it is the former.
The problem at the moment isn't just metadata on rips that is wrong, but metadata is inconsistent. To take an example, the composer Franz Schubert can show up as Franz Schubert, Schubert Franz, Schubert, Schubert F, F Schubert etc. The two discs in a two disc set may have different variations on each disc so that any search doesn't bring them up next to each other. So searching on composer in the app is quite frustrating. These are some of the issues we need to be able to fix and the upcoming firmware update should hopefully do that (but there are other more important bug fixes on Core that we are waiting for.)
best
Posted on: 17 October 2017 by Frances
I tried to do the test suggested above last night. I copied a ripped CD into the Downloads folder, then downloaded a metadata editing app onto my PC, then I discovered it wouldn't work on .wav files (even though its website said it would) and then decided it was dinner time.  (I've never actually downloaded music before - I've been happy with a combination of iplayer, internet radio and my CD collection).
I think David's answer above answers the question anyway.  So I can solve my problem by copying everything over into Downloads, finding a different metatdata editing app, and fixing it that way.
By the way, the NAIM app does allow me to edit genre, which I've been doing (although personally I'd like more categories as I'm only using about 6 of them and would love to split 'Classical - Chamber' out further, for example)
