Failing DAB rescan
Posted by: Kurt L on 17 October 2017
Today, the Belgian national radio stations went to DAB+.
So, in order to listen to them, I did a rescan of the DAB stations. Quite amazed to see that during scanning 46 stations were detected, but when I got the list, it mentioned "No stations available. Press List to rescan". So, I did that ~10 times with exactly the same result.
In the meantime I looked up the internet and read a factory reset would fix it. As I wasn't looking forward to spend my evening re-configuring my NDX, i tried a last thing. I disconnected my (amplified outdoor) antenna from the NDX, and let it scan. As expected, I found 0 stations. I plugged in the antenna again, and did a rescan. Et voila, al stations were there! I did this a couple of times and this is working in my case.
I also contacted Phil, who also recommended a factory reset. As this is quite drastic, best to try above as a last resort. ![]()
Hope this helps
