Hicap
Posted by: vilco on 18 October 2017
Hello,
I would like to buy Naim-Audio-Hicap-Olive
can I simultaneously power the pre amplifier and the cd player naim?
Thanks.
No, the Hicap can only power one device.
Depending on the Naim CD player you could use something like a Flatcap 2 which has dual outputs for this purpose. The CD5X had this option. Players such as the CDX2 / CDS3 need a XPS / 555PS type supply.
Vilco, I second all the advice given above with the minor change that a CDX2 will work fine without a power supply.
It is easier for the forum to help you if you list your system and tell of your naim ambitions. imo.
Chris_M
Christopher_M posted:CDX2 will work fine without a power supply.
Good point Chris - worth clarifying ![]()
sorry...
my system:
naim cd 5
nac 62
nap 150x
flatcap2
Best Regards
So Vilco what was your intention with the Hicap ? I take it from your first post that you have the FC2 powering both the CD5 and 62 ?
As already mentioned, the Hi-Cap can't power two items so can't just replace the FC2 but you could still use it to power the CD5 or the 62 (whichever combo you find to sound the best).
You can then use the FC2 (using a single output) to power what is left over.
The Flatcap2 Power Output B was specifically optimised for use with the CD5, so I'd probably favour doing that rather than keeping it on the NAC62 and putting a Hicap on the CD5. So if you get a Hicap then put it on the NAC62 and then dedicate the Flatcap 2 to the CD5.
A warning though... A Hicap that's in need of servicing can be a backwards step.
I will follow your advice.
Thank You.-
I have a hicap on my CD5 which replaced my Flatcap. The FC now powers my Nait XS 2. That's the fun part of this hobby - trying different combinations. Although when i look at all those cables a superuniti looks good...
I'm very confused,
please tell me how to connect my nac 62 to hicap (5 pin cable?)
My cd 5 to flatcap 2 (cable 5 pin)
Do Naim cables have a direction?
Best Regards.-
Yes, Naim cables are directional - the banded end goes closest to the source of the signal.
NAC62 connects to the Hicap via the SNAIC5 (each only has one 240 degree DIN5 so hard to go wrong here. The DIN5 is revealed when you remove the round black link plug. SNAIC banded end closest to NAC62). From the Hicap DIN4 (any of three) you connect via SNAIC4 (banded end closest to the Hicap) to the Power amp. DO NOT connect the power amp directly to the pre-amp when the latter is powered from a Hicap. This will work but can result in damage to the equipment.
The CD5 analogue output stage connects to Output B via SNAIC5 (banded end closest to the CD5). You will still need to provide mains power to the CD5 (the FC only powers the analogue output board). Signal goes straight from the CD5 via the grey interconnect.
Great...thank you. The problem is solved
I have another problem
the nac 62 that I have recently bought
it sounds so different that of the of my friend
even though they have almost the same serial numberi
The nac 62 of my friend has a very dynamic sound, it's more open.
I was somewhat disappointed with the purchase, what may be the cause of this difference between two the preamplifiers.
Thank you very much for your availability.-
With the old stuff by now there can be inconsistencies which only gets worse with age and use and all sorts of factors. You need to listen and choose accordingly. When was yours last factory serviced?
Type: Nac 62. S/No 80242
Thank you.-
The thing to do is to email Naim with that serial number and they will be able to tell you if and when the NAC62 was serviced.
It looks to me that you have only powered up the nac for about a day. When it is warmed up, it might sound better.
Yes, this makes a difference on Naim amps.
Hi
As you suggested I left my Hicap and My preamplifier on for two days
the sound is slightly improved but not much.
Let me do an example:
the volume knob of my preamplifier is at 12 o'clock to achieve a certain sound, the other preamplifier has the same sound as mine but with the knob at 8 o'clock
obviously the same Cables and Power amplifier.
we have dismounted both and inside are very similar.
How is it possible?
So long as the knobs are starting from the same point - i.e. they aren't orientated differently on the spindle, then that sounds like something is wrong. Has the previous owner modified the other NAC62 in some way? The only way to get to the bottom of it would be to have an authorised Naim service engineer take a look.
How did it turn out with the NAC62?
