Old chestnut. Nac 202. Power with flatcap or a nap 200?
Posted by: Bruss on 23 October 2017
I'm replacing a flatcap, nac 112, nap 150 all 3 box fronts, with a nac 202 plus napsc, and a nap 200.
2 questions.
Can I use the flatcap to power the 202 in the same way I do the 112? I see no reason why not.
Is there any advantage to doing so, over using the 200 to power the 202?
Posted on: 23 October 2017 by yeti42
Yes
Debatable
Posted on: 23 October 2017 by hungryhalibut
Yes you can, and no there isn’t.
Posted on: 23 October 2017 by Bruss
Ta.
Moderated Post:  Bruss, I have edited your post - please respect forum rules, thanks.
Posted on: 23 October 2017 by ChrisSU
Bruss posted:
The answer may depend on which 200 you have. If it's new, it will be a 200DR, and the DR specification applies to the preamp PSU, so this will sound better than, or at least different to, the old 200.
Apologies re the rules.
Unfortunately its an older fc2, not even an x to its name.
Posted on: 23 October 2017 by Fueller
Agree with everyone else here - I've owned all these units and also think Richard Dane mentioned the (old) 200 was equivalent to a flatcap as a preamp supply. Flatcap is therefore pointless in this setup. 202/200 with napsc is a very good combo, of course better still if the 200 is the newer DR.
Posted on: 23 October 2017 by NickSeattle
After I traded my 112/150 in, I found the FC2X came in handy when a Headline arrived.
Nick
