Checked my emails - looks like I've had the kudos Super 20s about four years now.
Stellar speakers.
Really have no idea where I would go from here - they're about as big a speaker as I would want.
Maybe it's time for the 500? Will it be wasted on the super 20s? Would that be a pointless upgrade given that I don't think I'll be upgrading the speakers anytime soon?
Current system - NDS/552/300- all DR except the 300.
Seems a little pointless to upgrade the 300 to DR spec - but If that's where the balance lies, maybe best to get a 300DR and push the 500 upgrade for the next home?
Or maybe best to do nothing at all?
(Second system is a 272/250DR) - got ridof the XPS-DR on a whim - miss it, but figured best to keep second system Spartan...
And had my first HiFi accident recently - kiddo accidentally nudged a set of standmounters the stand slipped on the slab and toppled over - no one got hurt luckily, but a couple deep gashes on those speakers make unsellable - those were the harveth shl5+ i use in the study with the 272/250..
Trying out the 250 DR in the big system.jnstead of the 300s tonight - hmm... The 250DR can't match the non Dr 300... There's so much info missing - hence the thoughts of moving to the 500DR from the 300....
Fwiw - got into a new hobby - me and my son - 6 yrs old now - go mountain biking every weekend. That is a lot of fun...
Posted on: 28 October 2017 by MangoMonkey
Baby#2 is 5 months old - and today is the first day after he was born that I've had a chance to sit down and listen to some music at night once everyone has gone to sleep...
Listening to water music suites/Trever Pinnock...
Pleasure/Feist prior to this
Posted on: 29 October 2017 by Huge
DRing the 300 is an interesting one. The 300DR is a beast of remarkable subtlety, delicacy and insight... It doesn't force you to listen, it just draws you into the music as though there was no other choice you could actually make.
Posted on: 29 October 2017 by Consciousmess
^ but I can’t help but wonder whether hearing the 500 DR in that fine system then heating a 300 DR might make your perception of the 300 DR sound compressed.
If the finances aren’t an issue, then the 500 DR should be your upgrade. Mind you, I bet you wish you had the hearing sensitivity of your 5 month old.
(An irony which always struck me - one can only afford the high end system when one is older with failing hearing...)
Posted on: 29 October 2017 by Chris Dolan
I would consider the NAP500 but would probably actually DR the 300PS - and also think about servicing the NAP300/300PS depending on their age.
Then think about a longer term plan - such as a 300 "four pack" going active with Kudos Super 20As (assuming the SNAXO works), or perhaps 606 or 707
Posted on: 29 October 2017 by Bert Schurink
I would suggest you upgrade to the 500. It brings you on a totally different level of quality of reproduction. Upgrading it to 300DR would also be an interesting step forward, but will be still quite a step away of what a 500 is capable off (own experience). The question of the speakers is a non question. Your speakers should fare well with the 500, the 500 will show what they are ultimate capable off.
Posted on: 29 October 2017 by MangoMonkey
The 250.2 and 250DR are different enough - that they shouldn't even have the same name.. and if you really liked the 250.2 - I'm not so sure you'll like the 250DR..
Not sure if the same rule applies for the 300 and 300DR...
From all reports, the 300DR is a different beast than the 300 - so I'll try to actually hear it before I do the upgrade.
With the amount of time I have, I figure I'll combine the 300 recap with DR upgrade at the 7 yr mark. That'll be in 2020.
No churn for now.
