Please fix Slide Over and Split Screen in the Naim App!
Posted by: CSI_Basel on 30 October 2017
See above!
CSI_Basel posted:See above!
Hi,
That functionality has been removed from the current app as it didn't work correctly in landscape mode and requires extensive rework to resolve - the function is scheduled to be reinstated properly at a later date.
Phil
<roger moore raised eyebrow mode = ON>
Phil Harris posted:CSI_Basel posted:See above!
Hi,
Phil
Would have been helpful if this had been stated in the release notes. Then I wouldn't have bothered to update....
I have an SU and Muso so couldn't care less about an improvement that only works with the new range.
Just bring back the slide over and split screen - for me it's been the biggest improvement all year!!!!!!!!
Any update as to when the next App update will be available?
I sent a mail to Naim Support as i have noticed that this version hunts for my rooms much more than the previous version.
How can one company get a piece of software so wrong especially as its the only way to control its products!!!!!!!
How can one person moan so much about something that doesn’t seem to worry anyone else and will be fixed in due course?!!!!!
HH might have a point - I don't even know what the thing that's gone missing is, having obviously missed it first time around!!
HH - having read a number of your posts - you seem to think you have a more important position within this forum than others.....
I actually couldn't care less what you think!!
CSI_Basel posted:HH - having read a number of your posts - you seem to think you have a more important position within this forum than others.....
Say what you mean CSI_Basel don't hold back! ![]()
That’s fine. And I don’t care about the slide over thing, as I have no idea what it is. I was just wondering why you are so exercised about it. Slagging off Naim when they have said that they are on the case is hardly helpful. I’m sure it will be fixed in due course, if that’s what Phil says.
I do agree that there are one or two folk here who seem to dominate and some even give contrary advice in the process - more boxes, less boxes, more boxes, denigrating certain products over time only to end up with them. Strange old world! There’s even one here who seems to be on a one man mission to bury the Core. Life is way tooooo short- move on.
jon honeyball posted:<roger moore raised eyebrow mode = ON>
Best comment here methinks, keep it up Jon.
I've never seen this "slide-over-split-screen_ thing. What does it do?
Or rather, what will it do when it's re-introduced?
It means you can have 2 screens open on the ipad. So one can be the Naim app and have Safari or some other app open too and both are active simultaneously. Allows you to multi-task
Very handy feature that got introduced on the later ipads a couple of yrs ago.
Cbr600 posted:jon honeyball posted:<roger moore raised eyebrow mode = ON>
I’m sure this feature will come back.
In 2018.
Maybe.
Thanks Jon - I think my older iPads don't support it. Anyway, I struggle to do more than one thing at a time as it is!
