NAS for NDX
Posted by: Dave Swan on 01 November 2017
Can anyone help here please?
I have an NDX and until recently have streamed directly from a USB drive plugged into the NDX. Using the Naim iPad app I can navigate folders by folder name, and within folders the music tracks are listed and played in order of their file names.
I have recently copied the files to a NAS (Zyxel NAS310), hoping to play from the NAS in the same way. While I can navigate folders as I would expect, within folders the music tracks are listed and played in an order that is independent of the file names. I think this is something to do with Twonky, and note that others have experienced problems with this component.
Since the NAS is quite old I am considering buying a new NAS specifically for music streaming. Has anyone got any suggestions for what device(s) I should consider? My main requirements are:
1 Folders should be listed in folder name order.
2 Music tracks should be listed and played in file name order. I don’t want to have to modify metadata to achieve this.
3 I don’t know if NAS devices affect sound quality, but I would not want the device to have a prejudicial effect on the sound
4 I am not too bothered about RAID or backup since the files on the NAS will be a copy not the master. The master files will be held elsewhere and will be (multiply) backed-up separately. A single-bay NAS would suffice.
5 Disc size isn’t too important. 1GB will be more than sufficient for now - I can always install a bigger disc later if required.
Any suggestions would be appreciated.
