Ethernet cables and tidal dropouts and a solution that has stopped the dropouts and made music more musical
Posted by: redalphabet on 05 November 2017
I have been pondering an audiophile ethernet cable and started out by buying an Audioquest Cinnamon Ethernet cable which bettered the bog standard computer one, I had plugged into the Naim streamer. It lowered the real body of the music without restricting the bandwidth of the music, subjectively - obviously better music.
After fiddling around with the system, I accidently touched it to another CAT cable I had coming out of the router, but not noticing this, I started listening to streaming music. That's when, for the first time, Tidal dropouts started! I switched to Iradio and Spotify and nothing, no dropouts. I thought initially I was finally plagued with the Tidal issues everyone complains to Naim about and blamed Naim in my head for crappy software - like i've been conditioned to by the forum.
As a loyal Naimy, I had a look around the back of the system and noticed that the streaming CAT cable was touching another CAT cable, I parted the two and the Tidal dropouts stopped, which is insane, seeing as the two cables are shielded.
If someone can explain why this issue plagues Tidal specifically then please do - but clearly it has to do with some latency issue on the server end of Tidal.
Anyhow - the shielding of ethernet cables isn't sufficient to stop cable crosstalk, which one can hear, and ineffective shielding is sufficient enough to destroy the data packets sent from Tidal to Naim when streaming Tidal, when two streaming cables are touching. Thats how crappy Tidal back system is, because if two cables merely touching can cause dropouts ANYTHING can, which is seriously miserable to comprehend.
I also had a touch of hardness on the Audioquest cable, along with the ineffective shielding - So I grabbed some plain old kitchen foil and wrapped it around the Audioquest and found that a 100% cover of its length actually 'Tuned' the cable and killed high frequency sibilance on the system and thus the hardness.
This Sibilance must be noise travelling down the cable from the router. It means that the 1's and 0's argument is destroyed because the argument does not account for noise in the transmission of the 1's and 0's which does affect music reproduction when the 1's and 0's are converted to music by the dac but clearly noise on the cable does not affect the transmission datacenter style data!
I decided that too much 'Tuning' had taken place as the last bit of 'air' had been removed from music when streamed - so I cut back the Tin foil shielding at the Naim streamer end by about 1/3 of the total length of the cable and the sparkle came back but none of the sibilance, nor hardness.
The long and short of this is that a Tin Foil shield for the Audioquest ethernet cable I use is essential for quality music playback - but that also - 1 meter of tinfoil actually affects sound quality - which in itself is bizarre.
Shielding streaming cables with Tin foil works, but like anything else, you've got to have the ears to hear it and a system that can resolve it.
Regards.
