NACA5 Question
Posted by: mikeybaby on 10 November 2017
My Naca5 cable is now 21 years old. Would there be any performance increase if I went with newer Naca5 cable?
Does it degrade over time?
Posted on: 10 November 2017 by yeti42
It might be worth getting new plug put on the ends but that's it
Posted on: 11 November 2017 by Adam Zielinski
Not really. Just clean the plugs and possibly have new ones soldered on if they have worn out.
Posted on: 11 November 2017 by ChrisSU
If you resolder the plugs, strip back some insulation, and make sure there is no discolouring on the wire, so that you are soldering nice clean copper onto the plugs. Sometimes this involves removing a few inches of wire at each end - hopefully this won't shorten the cables too much for your setup.
Posted on: 11 November 2017 by mikeybaby
Great!
Posted on: 11 November 2017 by NJB
I am in a similar position and was jolly glad that I reterminated mine. My local hifi shop of the time had made a right pigs ear of the soldered connectors. Cannot say I heard much difference but was reassuring to know that all was good
