Minimserver won't launch
Posted by: dikkiedirk on 13 November 2017
Sorry to ask this question here, but I can't register at the minimserver forum because I can't find the correct answer to the security question, how silly huh?
I decided to give minimserver a try and installed it on a Windows 7 PC and later on my Windows 2012 server. They ran just fine serving music to my Unitiqute. But this morning the fun was over minimserver failed to launch on both PC and server. Has anyone experienced this earlier? Can this be due to a Java update?
Posted on: 13 November 2017 by Nick Lees
If you have Java 9 then you need MinimServer update 106.
Posted on: 13 November 2017 by dikkiedirk
Well I have java 8 update 151 and I am in mimimserver 0.8.4. I don't know about minimserver update 106.
That should be OK then. What do the Minimserver logs say?
minimserver.log:
MinimServer 0.8.4, Copyright (c) 2012-2016 Simon Nash. All rights reserved.
Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
Java HotSpot(TM) Client VM (build 25.144-b01, mixed mode, sharing)
Platform default charset is windows-1252
System look and feel is com.sun.java.swing.plaf.windows.WindowsLookAndFeel
Integrity check failed for file minimserver.config
Startup complete
 minimserver threaddump:
MinimServer thread dump, produced at 20171113-141527
"Keep-Alive-Timer" id=19 TIMED_WAITING
 at java.lang.Thread.sleep(Native Method)
 at sun.net.www.http.KeepAliveCache.run(Unknown Source)
 at java.lang.Thread.run(Unknown Source)
"AWT-Windows" id=10 RUNNABLE (in native)
 at sun.awt.windows.WToolkit.eventLoop(Native Method)
 at sun.awt.windows.WToolkit.run(Unknown Source)
"Java2D Disposer" id=8 WAITING
 at java.lang.Object.wait(Native Method)
 - waiting on java.lang.ref.ReferenceQueue$Lock@166e5bd
 at java.lang.ref.ReferenceQueue.remove(Unknown Source)
 at sun.java2d.Disposer.run(Unknown Source)
"Attach Listener" id=5 RUNNABLE
"Signal Dispatcher" id=4 RUNNABLE
"Finalizer" id=3 WAITING
 - waiting on java.lang.ref.ReferenceQueue$Lock@d4004b
 at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" id=2 WAITING
 - waiting on java.lang.ref.Reference$Lock@1f5b51f
 at java.lang.Object.wait(Unknown Source)
 at java.lang.ref.Reference.tryHandlePending(Unknown Source)
 at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
"main" id=1 RUNNABLE
 at sun.management.ThreadImpl.dumpThreads0(Native Method)
 at sun.management.ThreadImpl.getThreadInfo(Unknown Source)
 at org.jminim.launch.Launcher.writeThreadDump(Launcher.java:1213)
 at org.jminim.launch.Launcher.launch(Launcher.java:292)
 at com.minimserver.launch.LaunchServer.main(LaunchServer.java:34)
I have to admit that means nothing to me. Are you running MinimWatch? What do the logs using MinimWatch say (right click on the Minim icon in the system tray)?
Posted on: 13 November 2017 by hungryhalibut
You are better to persevere in getting logged into the Minim forum, where Simon will be able to help you.
I have gone back to Asset upnp. Minimwatch turned red saying Integrity check failed for file minimserver.config.
A forum where I can't signup to because of a security question is of no use to me. Sorry Simon.
Posted on: 14 November 2017 by dikkiedirk
I miss interpreted the security, didn't see the difference between line and sentence because English isn't my 1st language.
Simon helped me out though.
But there is something wrong and Simon issued update 108 of minimserver.
You can read about it here:
http://forum.minimserver.com/s...p;pid=27630#pid27630
