Cant seem to get any sound out of my av channel
Posted by: How much ? on 15 November 2017
I have just recently purchased an a 5 din cable in order to listen to my TV through my hi fi. I have a Naim 202 PRE AMP AND A 200 POWER AMP. Can anyone advise me how to set this up as I have been following the manual and getting nowhere.
Gavin
Posted on: 15 November 2017 by hungryhalibut
You can connect the TV to any of the 202’s din inputs, other than the powered one. You don’t say what you’ve done already so it’s hard to advise. Maybe you need to enable the sound output on the TV.
Posted on: 15 November 2017 by james n
Have you got the right sort of DIN cable - some are wired as an output cable rather than an input cable ?
Posted on: 16 November 2017 by How much ?
Thanks for replying. I don't know what cable it is . I did buy it out of a hifi shop yesterday. Before that I was using a standard jack plug wired into the cd input and it worked fine. Now I have put the new cable into the av din socket and I am not getting any sound out.
Posted on: 16 November 2017 by james n
Does the new DIN cable work if you plug it into the CD input - if not then you have the wrong type of cable ?
On the other hand why not just use the jack plug lead you had already used into the CD input but plugged into the AV input instead - if it worked into the CD input then it'll work into the AV input.
James
Posted on: 17 November 2017 by How much ?
Thanks for all the replies.
I have found out it is an output cable as opppsec to an input cable . Hifi shop is going to send cable away to sort it out
once again thanks
Gavin
Posted on: 17 November 2017 by james n
Good news
