MinimServer / app
Posted by: al9315 on 18 November 2017
I am continually having to switch off my android pad, then switch it on again
I choose an album or a track, play it and press the button on the pad to put it on standby
Re-press it to choose another disc or track, and as often as not nothing. Current playlist is there, but not album list - MinimServer lost
Only solution is pad off/then on again - gets tedious.
Can anyone point me in a direction to try to solve this issue, maybe even why it happens ?
Much appreciate any assistance !
Posted on: 18 November 2017 by nbpf
Which control app are you using? Do you experiece the same problems when you try a different control app?
Posted on: 18 November 2017 by Dave***t
Not sure if it's the same phenomenon, but since the last update I've had trouble with getting back to the server list (e.g. list of artists if I had been browsing by artist).  I reported it to Naim support, but haven't heard anything more.
Does the less time consuming alternative of killing & restarting just the app not do the trick?  It usually does for me.  (Just in case, this means pressing the square 'recent apps' button, then pressing the x in the top right of the Naim app window.  Then pressing the circle/home button, then re-launching the app as normal).
