N-Serve update
Posted by: ChrisSU on 18 November 2017
I was a bit surprised to see an iOS app store update for N-Serve today. It claims that it 'Fixed crashes reported on iOS9.' Anyway, I updated it and now have version 2.12 (11514) instead of the old version, which was, .....errrrr..... 2.12 (11514). Or is this just the app store having a wobbly?!
I get this quite often with updates. A day or two later the same update is available. No idea why it happens. I don’t use the N serve app myself, but my App Store shows the version 2.12 was added a year ago.
Shows up as an 'update 20 Nov 2015'....
I see the Naim app has been updated too. And it gains iPhone X support apparently and that’s it
slow hand clap then.
n-Serve was last updated over 1 year ago as Adam points out. The Naim app, previously known as n-Stream, was the one updated last week.
Mike-B posted:n-Serve was last updated over 1 year ago as Adam points out. The Naim app, previously known as n-Stream, was the one updated last week.
So you might think, but there was an N-Serve update in the App Store this morning.
All I see is version 2.12 (???)
So do I, the point I’m making above is that it seems odd that it has appeared as an update in the app store.
An appleomaly
ChrisSU posted:I was a bit surprised to see an iOS app store update for N-Serve today. It claims that it 'Fixed crashes reported on iOS9.' Anyway, I updated it and now have version 2.12 (11514) instead of the old version, which was, .....errrrr..... 2.12 (11514). Or is this just the app store having a wobbly?!
N-serve can work on android? I did not find yet
No, it's always been iOS only.
ChrisSU posted:So do I, the point I’m making above is that it seems odd that it has appeared as an update in the app store.
Yes an update for n-serve appeared on both my iPhone and iPad yesterday, even though both were on the latest version. I accepted the "update" to get rid of the notification.
best
Finkfan posted:I get this quite often with updates. A day or two later the same update is available. No idea why it happens.
It's quite often because the app developer has issued a minor update a couple of days later to kill a bug that had been missed. If you look at the release date, it becomes immediately apparent what's going on.
best
The App store has definitely gone a bit loopy, it’s just come up with the same N-Serve update again. Hopefully this isn’t going to happen every morning!
I got it yet again yesterday. Weird!
best
I'm looking at n-Serve in the App Store and only seeing version 1.4, updated 12/03/15.
[Edit - which is for MacOS, I now realise.]
Richard Morris posted:ChrisSU posted:I was a bit surprised to see an iOS app store update for N-Serve today. It claims that it 'Fixed crashes reported on iOS9.' Anyway, I updated it and now have version 2.12 (11514) instead of the old version, which was, .....errrrr..... 2.12 (11514). Or is this just the app store having a wobbly?!
Yes, that's the Mac version - as you have now realised!
